| IMO, unless you already have the 34xx head or a line on one I would go with a 32xx head. We ran one for one yr on a 2388. The 32xx head is the same as the 3400 except has a two speed gearbox to change speed on the head whereas the 3400 doesn't as it's designed for a combine with variable speed feeder houses. We later put the 3200 on a 7010 but IIRC we had to buy an adapter to make it work. It was around $2,500 in 2009. We were also told to only hookup to the low side on the gearbox and use the combine's variable spd feeder house to change head speeds.
Edited by boog 8/7/2012 11:43
