| If you're a bit handy at metal fabrication.... save yourself some dollars on the 'kit' and fab your own brackets. You only need to remove the lower bracket for the gen, flip it over and elongate the bolt holes to slide it forward. DOne half a dozen of them now. Works perfect. The upper... you need to add an extension with a curve to wrap around the alt body... mabey 4-6" at most and that will work good.
If you call a certain blue dealer along the river and ask for bon you'll easily get the Tisco alt if you want too...
Rod | |
