Search Forums | Classifieds (199) | Skins | Language
IH Front rotor bearing housing
Jon Hagen
Posted 7/11/2012 16:10 (#2479702 - in reply to #2478331)
Subject: RE: IH Front rotor bearing housing
Hagen Brothers farms,Goodrich ND
We have welded them back in using nickle rod, they held and prevented wraping.
If you do buy a used one, make sure the bearing is tight in the bore. When the housing gets worn, the grease leakes out between the bearing and the inside of the housing, instead of flowing through the bearing lube hole.
