Posted 7/10/2012 21:32 (#2478282) Subject: Lil' Hoss and others
EC MN
Still trouble with brown box on 4700 sprayer. Reads ID 201 can Bus problem ( two can devices are requesting the same run page section) it says to run page layout to correct the conflict, but it will not preform this process. Also says fault code 110 (check wiring). Any suggestions which wires to check? TIA
