Search Forums | Classifieds (50) | Skins | Language
SULFER WATER, CAN IT BE FIXED?
2577
Posted 7/10/2012 22:58 (#2478539 - in reply to #2478236)
Subject: Re: SULFER WATER, CAN IT BE FIXED?
western NY
I was told if you put a plastic storage tank in basement vented to outside maybe a 4 inch pipe that sulfur gas will vent out and smell will go away.Try it in a glass or other container and see if it works. The only problem is you need two pumps,one with a float type switch in storage tank and the another to pump pressure to rest of the house.
