Southeast Florida | The problem with easy out's and small bolts is they expand the bolt when you try to turn them out. A left handed twist 1/4" carbide drill bit would be an option. I could probably do it with a MIG welder or a torch but this isn't my first try either. Is this a blind hole or a straight hole? A straight hole would be easy to blow with a fine tip on a torch and it can be done on blind hole but that ain't any fun. | |
