Posted 5/31/2012 22:32 (#2408281 - in reply to #2408199) Subject: Re: Good & Bad about Plate Planters
east central ND
got rid of the 71 flex for better depth control and same as others have stated - seed was not graded as consistant, and could hardly get the size I wanted in the variety I wanted....... Used to have good luck with med flats with the correct plate. With the rear tractor window open you could hear the knocker poping and the beans geeting a bit ground up.
