John Deere 7000 planter dry fertilizer settings
jjones71
Posted 5/9/2012 22:55 (#2376822)
Subject: John Deere 7000 planter dry fertilizer settings
I just purchased a used JD 7000 4 row planter. I got everything with it except the manual. I need to know how to set the transmission up on the dry fertilizer. I'm wanting to put 100lbs/acre on.
THANKS!
Thud
Posted 5/9/2012 23:09 (#2376840 - in reply to #2376822)
Subject: Re: John Deere 7000 planter dry fertilizer settings
Near-north Ontario, French River
What augers do you have in the boxes? High capacity augers the 'flighting' will almost touch in the middle, the standard augers will have a fairly large gap between the two augers ( 4 inches or more ??? been a while since I've looked)
jjones71
Posted 5/10/2012 07:12 (#2377143 - in reply to #2376840)
I have the standard augers
Thud
Posted 5/10/2012 17:18 (#2377696 - in reply to #2377143)
http://www.imarksweb.net/book/jd+7000+4+row+planter... follow this link, you should be able to download a copy of the rate charts.
