Search Forums | Classifieds (16) | Skins | Language
Case 2594 24 speed problems
Alpine
Posted 3/18/2012 22:17 (#2294376)
Subject: Case 2594 24 speed problems
IN
My dad has a 1984 Case 2594 24 speed tractor. When using the 6 speed selector shifting from first through sixth tractor does not engage into second and fourth gear (ground speed does not increase) . Although when shifting back down from sixth through first all six speeds engage correctly.
After tractor warms up then tractor shifts correctly majority of the time. Anyone have any ideas? TIA!
wayneNWAR
Posted 3/18/2012 22:44 (#2294466 - in reply to #2294376)
Subject: RE: Case 2594 24 speed problems
north west arkansas
I dont know nearly as much about the 94 series as I do the 90 series but I do have two 2594. The only problem I ever had is the electrical control box inside the console went bad. One mine one time it would shift fine and one time it wouldn't. There is a actuater switch inside the console that could be acting up, but I dont think its that. My guess is either that control box or one of the solenoids on the side of the transmission.
Jon
Posted 3/19/2012 08:46 (#2295015 - in reply to #2294376)
Callao Missouri
Sounds to me like you have a weak magnet on the shift solenoid some where. Jon
