Search Forums | Classifieds (144) | Skins | Language
Anhydrous break away coupler
white caddy
Posted 3/10/2012 13:57 (#2279334)
Subject: Anhydrous break away coupler
Central Nebraska
We are changing our break away coupler on the NH3 rig. Our dealer gave us a Squibb Taylor Flo-Max II coupler. This morning we were figuring out how it exactly works so we attached a hose and coupled it together and tried to pull it apart. Had 3 people on the hose trying to pull it apart and couldn't get it to come apart. On our old Pioneer coupler I can pull it apart without any difficulty. Does anyone have one that pulls apart easy or has had a situation where the coupler came apart as it was supposed to? I'm afraid that if the coupler would have to come apart, it will ruin the hose before the coupler comes apart.
Thanks
Mike
bowtieighth
Posted 3/10/2012 14:09 (#2279352 - in reply to #2279334)
Subject: RE: Anhydrous break away coupler
Bethany, MO
Can you take it apart manually?  I've never tried to PULL but I've jerked them apart and it takes some effort.  The operators manual says 200 to 300# of force.  That's all we use.  There's always the chance of a bad one.
http://www.squibbtaylor.com/iommanuals/nh3/fm125iom.pdf
as8509
Posted 3/10/2012 14:56 (#2279411 - in reply to #2279334)
Subject: Re: Anhydrous break away coupler
We quit using the breakaway couplers because the few times we have lost a tank, it tore the hose up anyway.
ILMOfarm
Posted 3/10/2012 15:37 (#2279463 - in reply to #2279411)
I wouldn't be telling that if you are in IL. State law here requires one breakaway for each tank. And yes they come by and check compliance every year.
bowtieighth
Posted 3/10/2012 15:38 (#2279466 - in reply to #2279411)
Bethany, MO
as8509 - 3/10/2012 13:56 We quit using the breakaway couplers because the few times we have lost a tank, it tore the hose up anyway.
Interesting............
white caddy
Posted 3/10/2012 22:08 (#2280074 - in reply to #2279334)
Central Nebraska
After dinner we mounted it up to the rig and put the hose end on an old hose and tied to the ATV with a chain and "simulated" a break away. It worked both times we tried it with the ATV and then my brother just pulled it by himself and it came apart, so no concern. Dad figured that we better test it so we know it works, would hate to find out the hard way.
