| Does anyone have a list of error codes for a 2004 8103 terrashift transmission? they pop up occassionly and is very annoying it runs and shifts fine i think its some sort of sensor gone bad |
Belwood, Ontario | what are the codes? |
Zabcikville, TX | I've been driving a Terra-Gator for years. E85 is one that comes to mind. Parking brake applied, will not let it shift. You prolly know that already. Any codes we have had are usually (not always) wire plugs and coils on the tranny. We try not to chance it on the tranny, been told a rebuilt one is 24k. |
Belwood, Ontario | 2004 is a CAN BUS machine, so it may be CAN errors you're getting, get me the codes and I'll get you descriptions |
| ill have to look and see what the are i think one was E856 or E859 will double check and get back |
Belwood, Ontario | yep those are CAN codes
e856 over temp/current left turn signal
e859 open load right turn signal
Let me know for sure or any other codes you get |
| yes its e859 so how do you fix the problem? |
Belwood, Ontario | open load means that it is not seeing an amperage being used by that circuit, are all the bulbs good, is the wiring good, should be an easy fix |
| air max on this machine impossible to keep fert out of rear light wires. i have repaired several green wires and recently replaced the whole wiring harness will see if this cures my problems.
thanks sprayertech |
Belwood, Ontario | anytime |
