Search Forums | Classifieds (255) | Skins | Language
Hp requirements for a bourgault 5710
jeff gordon
Posted 10/16/2011 08:32 (#2005980)
Subject: Hp requirements for a bourgault 5710
Mather, Manitoba
Looking at updating to a bourgault 5710, 6450 tank, with mid row banders. 10 inch spacing. Have a tow between 3000 gal liquid caddy that we haul as well. What hp do I need to pull it? Pretty flat land.
STSFARMER
Posted 10/16/2011 08:58 (#2006019 - in reply to #2005980)
Subject: Re: Hp requirements for a bourgault 5710
NW NORTH DAKOTA
We have a 60 ft without band,and no caddy with a fair amountof hills and our 535 quad gets a workout climbing the hills. Add the caddy and banders on flatter ground and it will be close to the same. Run mid 80's percent of power in flat ground and in hills 100 to 112 percent.
SWND
Posted 10/16/2011 09:10 (#2006038 - in reply to #2005980)
Subject: RE: Hp requirements for a bourgault 5710
Southwest ND
How many feet of drill? Pulling a 47' with MRB'S and 6450 TBH cart takes 425HP at least in good hills.
CND
Posted 10/16/2011 10:51 (#2006215 - in reply to #2005980)
Anamoose, ND
Have the same set up as SWND along with double NH3 carts, it is doable with 425 hp but 480+hp works way better. What size drill and what size tractor are you planning on using? On flat ground the airseeder pulls easy, it is all the weight in the hills that kills you.
jeff gordon
Posted 10/16/2011 11:31 (#2006252 - in reply to #2006038)
Mather, Manitoba
48 feet of drill with pretty flat land.
Bought a 400 Versatile. 435hp
Edited by jeff gordon 10/16/2011 11:33
SWND
Posted 10/16/2011 20:04 (#2006769 - in reply to #2006252)
Southwest ND
With 435hp in level ground you will be just fine. Always seems like air drills pull twice as easy on level ground than in in serious hills.
