Near Intersection of I-35 & I-90 Southern Mn. | 4020eyes - 1/10/2011 22:32
what is list for clutches for my Kinze 12 Row planter and EZ500? I would need the ez boom to. Can I do Ag leader sure stops?
I don't know abut the price.
If you are using EZ-Boom for a planter with their cables, the expectation is that they will be connected to Tru-Count air valve box(es). This cable terminates in 6 pole weatherpaks which are connected to the valve box(es). There is one for Sections 1-4, another for Sections 5-8 and a third for Sections 9-10.
The Ag Leader Surestop cables are identical for each "half" of the planter. These cables start with a 24 pin AMP connector and split up for each row with 2 pole weatherpaks to connect to the Surestops. There are several possible Surestop cables depending on the number of rows. For example a 16 row planter would use two identical 8 row harnesses.
This means that the EZ-Boom planter cable will not mate with the Ag Leader Surestop cables. We make adapter cables that allow the two to be connected. Because the row harnesses are identical, the adapter cables cannot be identical but need to be "mirror images" for the section splitup.
There are several possible variations. A common combination that I made last Friday was for a 16 row planter split up into 8-2 row sections.
I have a set of adapters on the shelf that I made for a 12 row planter setup for 6-2 row sections. If the 12 row were setup as 4-3 row sections then a slightly different adapter would be needed.
Edited by tedbear 1/11/2011 06:57
