AgTalk Home | ||
Freightliner will not build up air pressure? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
tomosakis |
Osakis, MN | New to us truck wouldn't build up pressure for me yesterday. Needed to move it to get to the snowblower. Compressor sounds like it has a knocking sound and it's pretty hot to the touch. I started the truck and left it for about 15 minutes, did a few other things and when I went to move it the alarms were buzzing and the air gauge had not moved a bit. Could there be an open valve or something? I'm pretty much a truck virgin so pardon my ignorance! Engine is 370 hp M11+ if that makes a difference. And the truck has been here for a couple months, and never had a previous problem. The air temp outside was probably about 17 degrees so there could be a ice issue possibly too. | ||
breken |
Flora Indiana | There is good chance there is ice in the main line from the pump to your air tanks. Had this happen to us before. We took the line loose from the the pump and dumped some air line deicer in it. Good luck! | ||
5250JB |
Jerseyville,IL | Check air governor on side of compressor. Check for ice in airlines . If truck has air dryer check for air to dryer. First bet would be air governor . JB | ||
hillfarmer |
if the line to the air dryer is froze the relief on the compressor would blow I am guessing there is a leak at the dryer | |||
Thud |
Near-north Ontario, French River | I'll second Brekens theory. Sounds like you are froze up between the compressor and first air tank . You said the compressor is hot to the touch so that tells me its trying to build pressure , but the airs not getting to the tanks as shown by the pressure gauges.. Remove the line from the top of the compressor, pour some airline anti freeze in , let sit for a couple minutes and fire it up. If its builds pressure then I suggest getting the truck into a warm shop to let any residual ice melt out of the lines, and tanks. Then drain all the air from the tanks to remove the moisture. If you plan on using the truck in the winter you might want to add a dryer system , or at the very least an alcohol system to the truck to prevent the problem in the future. | ||
flinkster |
Osnabrock ND | I'm gonna say the air dryer is froze. Have had this happen a few times. Take the two lines off of dryer and hook them together. Have done this to get by. It's easy to take line off from compressor to check if air is getting to dryer. | ||
tommyw-5088 |
south Texas , York Rife Freemason | Take line off compressor fisrt , see if it is pumping , have engine off and zero air pressure when you do this . Sounds like ice to me too . | ||
RodInNS |
You've got a frozen airline. My old COE would freeze the mainline at a brass elbow where it was bolted to the clutch housing. Regardless... you need some air brake antifreeze. What I do is get a spray bottle and pour some brake antifreeze (which is basically methyl hydrate with some rubber conditioners) in the bottle and set it to spray a fine mist. Then remove the intake hose from the compressor (it's probably hooked to the intake manifold on the engine)... then start the engine and spray a mist of alcohol into the compressor intake. A very small amount as you don't want to hydro lock the compressor! Doing this a bit at a time until it thaws will work. You can also dump the alcohol into the line to the tank if it's easy to remove... but mine wasn't so I misted it into the compressor. It thawed in a couple minutes. Rod | |||
tomosakis |
Osakis, MN | Thanks for the replies, I went to town today to get a few things one of those being airline antifreeze, came home with everthing I needed and then some, except I forgot to get the antifreeze. I can't imagine what it's going to be like when I get old, if I can't remember anything already!! I was going to get it, right after I made a stop at Wally World, after being in there for a few minutes I just wanted to be done shopping I guess!! | ||
(Delete cookies) | |
