AgTalk Home | ||
Input on a 4040s JD tractor Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
HYDE |
North Carolina | Guy down the road is looking to sell his 4040s is has 5500 hrs, HFWD, cab, in so so shape. What's the down low on this import 4040s, good and bad. Also, what's the good and bad of the HFWD. I personally don't like the HFWD, but what can be the problem of not using it, except on the rare occasion. The motor has France on the plate. Thanks | ||
zkeele |
Tennessee | We have a 4040 with a loader on it, 2wd. I think John Deere used the 4040 to use up the old 30 series parts. It has the same rear end as a 30 series and has the smaller 404 engine without a turbo. Ours does not have a cab and is relatively trouble free, but for some reason I just don't like it. If you could swing the extra cash, a 4050 or 4250 with MFWD would be a better tractor. Edited by zkeele 11/20/2010 18:57 | ||
yallardeere |
I think the one you are looking at has a 359 in it......... | |||
Steiger Man |
Sunburst Montana | Is it actually a 4040S built overseas or a 4040 from Waterloo. The info is kinda conflicting because I always thought the 4040 from Waterloo used the 404 engine with the option of hydraulic front wheel drive (HFWD) and 4040S had the 300 series engine with the option of mechanical front wheel drive (MFWD. | ||
hagkat |
Hawesville, KY | It is not HFWD, it's really a HFWA. There is no drive to those things, but merely a very little assist. The only thing that makes them better tha 2WD are the bigger front tires. If you've ever owned a MFWD you will be badly disaappointed in the HFWD, it's nothing close. If it was made overseas it should have a place for a liscense plate on the top back of the cab and turn signal lights on the front sides of the hood. I also believe JD didn"t offer the MFWD until the 50 series, which is what would recommend if you want FWD. | ||
Steiger Man |
Sunburst Montana | If you want to get technical, JD called it "Power Front Wheel Drive." Thats straight out of the manual and brochures. | ||
HYDE |
North Carolina | Yes it's a 4040s, it has the lights on the side of the hood, trailer plug, pull up emergency brake and all. | ||
candyo1955 |
Livinston Co. Il. | No emergency brake on our 4040 . It must be foreign. A/C only problem I've seen . | ||
retento |
Eastern North Carolina | The OP said it was a 4040"S".... Nothing like the US built 4040.. Looks like this one I bet.... http://www.equipmentlocator.com/asp/eDetails/JOHN+DEERE/4040S/e... Edited by retento 11/21/2010 08:16 | ||
HYDE |
North Carolina | Yeah retento, it looks just like that one. | ||
(Delete cookies) | |
