Posted 4/29/2006 08:36 (#8604 - in reply to #8552) Subject: RE: Zimmatic wiring code
I would look at
1- Precent timer
2- Collector ring at pivot, above panel, for loose wire
3- Loose wire as Dave said, going through each switch to end tower. Set percent timer at pivot on O and follow power from 1st tower, on out to the end. Check each micro switch with voltage meter to make sure power is flowing through to the next tower.
