Search Forums | Classifieds (22) | Skins | Language
Fertilizer weights?
dakota
Posted 4/27/2010 21:45 (#1177144)
Subject: Fertilizer weights?
SC North Dakota
What is the average weight per cubic foot of 46-00 and 11-52-00 fertilizers? Any good sites to explain the use of fertilizers? tia
floydchristmas
Posted 4/27/2010 22:03 (#1177189 - in reply to #1177144)
Subject: Re: Fertilizer weights?
i do most the fertilizer spreading on our farm and the 46-0-0 is always 48 density, or 48 lbs/cu. ft. im not sure what 11-52-0 is but around here we get dap as 18-46-0 and the density on that is going to be somewhere in the 65-70 lb/cu. ft range.
billybob77
Posted 4/27/2010 22:16 (#1177217 - in reply to #1177144)
Subject: RE: Fertilizer weights?
Southern MB
11-52-0 weighs 55 lbs per cubic foot
jeff gordon
Posted 4/28/2010 01:17 (#1177534 - in reply to #1177144)
Mather, Manitoba
11-52-0 is 60lbs/ft3
46 0 0 is 48lbs/ft3
SDFarmboy
Posted 4/28/2010 22:53 (#1178621 - in reply to #1177534)
These weights can vary, I assume you have a density scale, for test weights of grain and weight per cu. ft. check it out for yourself.
This is from NDSU Fert. Guide;
46-00 45 # Density, lb/cubic foot.
0-0-60 65#
11-52-0 55#
18-46-0 55#
If you don't have one, get a density scale, and take the time to get yourself educated. Go to your county ext. agent and learn. That is what farming is all about.
