plowboy - 4/11/2010 20:09 Is it really a good thing for an oil to cause o rings to swell up? If I saw that I would take it as an indication that i had the wrong o ring and it was not compatible with the fluid in question.
It was for me, but then the old 1086 was leaky....nice to have the mess gone. Compatibility, doubt that would be an issue in something that was supposed to use Hy Tran to begin with. When we started using HyTran in the old Hesston windrower the leaks slowed up quite a bit, easier than rebuilding stuff. Although at the time I had no idea the oil had anything to do with it. |
