Search Forums | Classifieds (60) | Skins | Language
Fitting on 250 gallon tote?
DonOK
Posted 4/3/2010 22:34 (#1148936)
Subject: Fitting on 250 gallon tote?
I received a tote with an odd fitting. It is male with really corse threads. It is similiar threads to the the bung on a 30 gallon drum. (not the pipe bung but the other side) Can an;yone help identify this style, and where can I find a fitting for it? I need to go to 2" quick couple male.
TIA
plowboy
Posted 4/3/2010 22:41 (#1148957 - in reply to #1148936)
Subject: Re: Fitting on 250 gallon tote?
Brazilton KS
It is a buttress fitting. The threads on the valve are the same as the ones on the tank. If you have an empty tote which you can hook up to, you can just unscrew the valve off of the empty tote and it will screw onto the output threads on the valve you are asking about.
Thanks to another Agtalker for telling me that last year!!
RICK NCMD
Posted 4/3/2010 22:43 (#1148960 - in reply to #1148936)
Subject: RE: Fitting on 250 gallon tote?
Looking past the threads, does it have the receiver groove for a 2 inch female Banjo coupling?
plowboy
Posted 4/3/2010 22:45 (#1148966 - in reply to #1148960)
Brazilton KS
I've seen that on a lot of pipe thread valves, but I have never seen a buttress with that setup.
DonOK
Posted 4/3/2010 23:00 (#1148991 - in reply to #1148966)
Like Plowboy I have seen that with pipe threads. I did check that already, but no luck. I will try a valve from another tote if I cannot find an adapter to pipe.
Thanks for the help.
RICK NCMD
Posted 4/3/2010 23:00 (#1148992 - in reply to #1148966)
I had one on a bulk oil tote that drove me nuts, until I spoted the Banjo part. The Buttress thing is new to me, got any pics.
DonOK
Posted 4/3/2010 23:17 (#1149022 - in reply to #1148992)
I think this is the adapter I need. 2" buttress male x 2" pipe female. Look at KB338 about 3/4 down the page. http://kowabunga.biz/drumadaptersplugssafetyseals.html
plowboy
Posted 4/3/2010 23:34 (#1149048 - in reply to #1148992)
Brazilton KS
This is the valve he has, or similar to it.  The male side is the same threads as the female side which screws onto the tank bladder.
Many IBC have this valve insead...it screws onto the same fitting on the bladder of the IBC, but has NP on the other side.  I almost typed NPT, but I would not be surprised if it is actually NPS since the cap has a gasket.  For our purposes either will work.
Edited by plowboy 4/3/2010 23:36
RICK NCMD
Posted 4/3/2010 23:36 (#1149054 - in reply to #1149048)
Havent run into that one yet. Thanx for the pics
plowboy
Posted 4/3/2010 23:40 (#1149062 - in reply to #1149054)
Brazilton KS
I think the bottom one is probably actually BSP on the male side.  Again, for our purposes they are interchangeable at low pressures.  Here is an adapter to fit on the buttress thread and go to BSP...but just screwing the valve off of an empty IBC is a lot cheaper.
DonOK
Posted 4/3/2010 23:42 (#1149065 - in reply to #1149054)
I think this is the cure.
http://www.actionsealtite.com/Products/IBC-Fittings/Adaptors-and-Co...
plowboy
Posted 4/3/2010 23:44 (#1149070 - in reply to #1149022)
Brazilton KS
I think you need the buttress to be female and the pipe to be male.
plowboy
Posted 4/3/2010 23:46 (#1149072 - in reply to #1149065)
Brazilton KS
I am not sure without reading more....but I think you need 50mm buttress, not 60mm.
Anyway, I know the valve from another IBC which has pipe threads will work.
edit: I'm now almost certain you need 50mm.
I searched all over for them last year, and the only options available in the US were grossly overpriced....empty IBCs are pretty close to worthless, so I just stole a valve out of one.
Edited by plowboy 4/3/2010 23:50
dutch
Posted 4/4/2010 00:01 (#1149090 - in reply to #1149065)
West Texas
Must have gotten a tote from UAP or CPS?
I had a lot of trouble with their tote fittings until I got them to give me some adapters for them.
Clay-All-Over
Posted 4/4/2010 00:01 (#1149091 - in reply to #1148936)
Eastern Ontario
Thank you for posting the question. I was going to post the exact same thing tonight. What a coincidence.
I think I will rob a valve off another IBC and see if it works.
DonOK
Posted 4/4/2010 15:27 (#1149744 - in reply to #1149091)
Subject: Thanks Plowboy. NT
NT
plowboy
Posted 4/4/2010 17:00 (#1149806 - in reply to #1149744)
Subject: RE: Thanks Plowboy. NT
Brazilton KS
I searched.  Credit properly belongs to Jay NE Ohio for that one.  That's where I learned it.
jrich
Posted 7/9/2010 10:24 (#1266404 - in reply to #1148936)
Your fitting is a buttress adapter. You can purchase them at spacekraft.com
A few other sites make them as well. Don't pay more than 10.00
milofarmer1
Posted 7/9/2010 14:05 (#1266578 - in reply to #1148936)
Farwell, TX/Pleasant Hill, NM (Western Panhandle)
If it was me I would probably scrounge up a piece of soft 2" rubber hose, a couple hose clamps, and a pipe nipple and make a cobbled up mess that would leak everywhere.
Didn't somebody on here do something similar with a Mt. Dew jug for spray water....................
Edited by milofarmer1 7/9/2010 14:06
Adrian
Posted 7/9/2010 20:09 (#1266886 - in reply to #1266578)
South Georgia
Yeah, I remember the Mt. Dew / tape thing. Wasn't that Rich? Speaking of which, I haven't seen him around lately, have I?
Adrian
