Search Forums | Classifieds (127) | Skins | Language
spray booms on 4-wheeler
nbfarms
Posted 2/14/2010 21:19 (#1074955)
Subject: spray booms on 4-wheeler
I am wanting to make a boom four our 4 wheeler. Id like to have it like 8-10 ft with it able to fold up to the width of the 4 wheeler. I've heard of some that have them spring loaded so that if u hit something they bend backward. If anyone has pics of ones they've made or bought id like to see some. Thanx in advance!!
lancef53
Posted 2/14/2010 21:27 (#1074972 - in reply to #1074955)
Subject: Re: spray booms on 4-wheeler
Portland, ND
Get a boomless nozzle, they work awesome. I think they come from smucker?? Polaris sells them for their rangers. I have a set of fold up ones, and they are too low for lots of crops by the time you get the wheeler weighted down. The boomless one is much nicer to work with.
DIESELDAN74
Posted 2/14/2010 21:28 (#1074976 - in reply to #1074955)
Ever thought about a boomless nozzle Hypro and Teejet make them? They might spray a little wider than 10' feet though.
Stacy
Posted 2/14/2010 22:18 (#1075103 - in reply to #1074976)
Triplett / Brunswick MO / Brookfield
You can look at the small fold up booms at Orschlens. I have one, and don't use it. We spray several acres of CRP every year, as well as our lot, and we also spray for skeeters around the house. Since we aren't wanting a kill on the CRP, but rather just to retard growth, we use one tip that is supposed to spray 43 feet. If I remember right, I think we run close to 40 lbs of pressure, and the real width is more like 30-33'. We spray 15 MPH and use about 2 - 2.25 gallons per acre. Spraying our lot for weeds, or around our home for skeeters, we spray about 12 - 15' wide, 5-7 MPH and do a good job.
My SIL has a boomless sprayer set up with three tips, it's no wider than the 4-wheeler, but has a pretty good sray width as well as good coverage.
When buying or setting up a 4-wheeler sprayer, I would for sure suggest big amp motor (ours is 3.8, but you can get 5 amp ones now), return line, small sump if possable, an on off switch. Make sure the wire you use is heavy enough to do the job, because we found the first ones we bought would get hot enough to melt the plug where you connect and dissconect the power.
m3farmer
Posted 2/14/2010 22:05 (#1075056 - in reply to #1074955)
SW Minnesota, Lyon County
Boomless ones are nice in ideal conditions. Mix in a slight wind and they are junk. I have both for my Ranger. I use the regular boom most of the time. I have one boomless nozzle that I use for spraying road ditches but conditions have to be right. I went to a Tractor Supply or some other farm store to get an idea for my booms. Make sure you have them spring loaded because you will eventually hit something. Also, make sure you don't hinge it where a nozzle needs to be.
Posted 2/14/2010 22:12 (#1075078 - in reply to #1074955)
Subject: RE: spray booms on 4-wheeler
Previous post I made.
http://talk.newagtalk.com/forums/thread-view.asp?tid=105008&mid=743003#M743003
btfarmer
Posted 2/14/2010 22:17 (#1075098 - in reply to #1074955)
W Mn
Emergency Sprayer.
(028.jpg)
(029.jpg)
Attachments 028.jpg (73KB - 472 downloads)
Attachments 029.jpg (81KB - 474 downloads)
Rich
Posted 2/15/2010 02:03 (#1075364 - in reply to #1074955)
Kansas
Now if I can find the pics........which I know are on this puter somwhere........ I made some for my gator but I don't recall if I have any of them folded up.
Breakaways would be simple enough to make, I just opted for the "quick and easy" design and promised myself I wouldn't hit anything with them. ;-)
(BTO spray rig.jpg)
(BTO spray rig 1.jpg)
Attachments BTO spray rig.jpg (91KB - 396 downloads)
Attachments BTO spray rig 1.jpg (73KB - 414 downloads)
myfarm
Posted 2/15/2010 07:36 (#1075443 - in reply to #1074955)
http://www.fimcoindustries.com/images/catalog/09/atv_boomkits.pdf
lancef53
Posted 2/15/2010 07:42 (#1075447 - in reply to #1074955)
Portland, ND
The boomless nozzles work great with a little drift retardant mixed in(i use interlock), and the width can be varied by adjusting the height of the nozzle. The only place I am a little nervous is in the yard around the garden and flowers.
SD-455
Posted 2/15/2010 09:28 (#1075580 - in reply to #1074955)
Northeast Indiana (Auburn)
Fimco sells a 7 drop 20" spacing spring loaded folding boom. Farm stores like TSC sell them I bought mine on eBayfor around $100.
joe
Posted 2/15/2010 12:27 (#1075828 - in reply to #1074955)
I built this one and it works well for me. If I could have found one at the time for 100 dollars I would probably have just bought one. I have little invested in this except time, but it took me a while to get it the way I wanted.
(gator sprayer 010a.jpg)
(gator sprayer 005a.jpg)
(gator sprayer 023a.jpg)
(gator sprayer 019a.jpg)
Attachments gator sprayer 010a.jpg (86KB - 399 downloads)
Attachments gator sprayer 005a.jpg (80KB - 416 downloads)
Attachments gator sprayer 023a.jpg (96KB - 400 downloads)
Attachments gator sprayer 019a.jpg (85KB - 419 downloads)
