Ethridge, TN | <p>I would honestly look at changing everything over the twist locks. See what your highest draw is, and then choose the next size higher than that. Remember, the more length you are coupling together, the more resistance you are adding. The twist locks have heavier, bigger, prongs on them. I don't mind welder plugs on the welder and that stuff where it's inside, but I've had enough problems with them on the outside to not want them around a bin site. Plus, seems on the cords, the receptical ends with a welder style plug were always getting busted up. The twist lock ends seem to have a better survival rate.</p><p>Just about forgot, get the LARGE cord ends, not the smaller ones that are about as big as what you have. I can't manage to remember the NEMA# for the ones I use, but they are actually a 3 prong 3ph end. The smaller versions are not much better than you already have. <br /></p>
Edited by ChrisTN 2/1/2010 08:57
