12 x 30 Case 1250 planter pulled with a Challenger MT765, InSight controls. STMM monitoring the seed flow. CCM running the factory section clutches (2 sections). Starter fertilizer controlled by the LCM. Ace hydraulic centrifical pump with Mid-Tech electric bypass valve, raven flow meter and Banjo ball valves. (2 sections). You could do the same thing with a ground drive pump. Set the pump to a higher than necessary flow rate and let the excess bypass back to the tank. Use a flow meter and electric bypass valve (3 way valve) to control the rate.
(2009CornPlant015.jpg)
(2009CornPlant016withText.jpg)
Attachments ---------------- 2009CornPlant015.jpg (89KB - 83 downloads) 2009CornPlant016withText.jpg (73KB - 84 downloads)
