Search Forums | Classifieds (40) | Skins | Language
CaseIH Puma 170 with Agleader SteerCommand
kgbarnett22
Posted 3/22/2017 08:15 (#5915088)
Subject: CaseIH Puma 170 with Agleader SteerCommand
NE Indiana
Has anyone put a steercommand or a geosteer in a Tier 4 puma. Ours is a 170. I cant get the steer command to calibrate. It says failed to find valve deadband. I just got a cable ordered that will tie the Steercommand into the tractors CAN system but from what I read that is just so the wheel angle sensor information gets back into the tractor to disengage the auto mfwd. After is says that failed it says check valve and wheel angle sensor. When I go into the wheel angle sensor it appears to be working all the way left gives a number like 65100 and all the way right is like 65400. This tractor was previously steered with an FMX and nav controller and that worked fine. Valve works correctly when its trying to calibrate.
