Butterfield, MN | As long as your section widths and speed are accorate, the 440 should be covering as much ground as it says it is. That being said, is there any chance that the guidance width is a little off in the FMX for some reason? Any reason it might have been changed for a different implement? A little far fetched since it's strip tilling, but there has to be some reason. Did you try doing a distance test to see if the distance driven is the same as that on the 440? | |
