WNW Illinois, Henry Co | My guess is you have one side set higher for rate control then the other, Maybe??.
hope that helps,
look at you seed scan or seed by section, cannot remember which, to check they at the same.
good luck,
Edit: also looking at your vacuum, do you need it that high and where are the setting on the knockoffs, I usallly run about 18 to 19 once with exceptional big seeds, 22 inches of water. and you need more planter to only use 55% of your hp. mine pegs 76 to 100 most of the time. lol.
Edit Edit: after looking again, put in you layout of seed section 1 and seed section 2 to get seed by section. yours seed section average is the average of both sides hence it is right on the money . I think the red line is 100% and irreletive of pop. so 100 % if 30 K is closer thanb 100% if 34,5. K.
Just thought of something else. are both wheel cal numbers very close to same, dont know if make a diff. usually it is something really simple , it is just finding it.
good luck again.
Edited by newag1 5/3/2011 23:44
