Search Forums | Classifieds (66) | Skins | Language
Propane and galvanized pipe
mtbrights
Posted 12/21/2010 11:39 (#1498661)
Subject: Propane and galvanized pipe
Carter Montana
Can I get by with a couple of galvanized fittings for a shop heater rather than black. Just need maybe a street L and a T. The internet has conflicting opinions on this.
7720gas
Posted 12/21/2010 11:43 (#1498667 - in reply to #1498661)
Subject: Re: Propane and galvanized pipe
no,
Jon Hagen
Posted 12/21/2010 12:40 (#1498742 - in reply to #1498661)
Hagen Brothers farms,Goodrich ND
The zinc coating does not react well to propane.
The chance of sluffed off zinc trash hanging a regulator or gas valve open makes for too much risk,
Delmarva Ag
Posted 12/21/2010 12:45 (#1498749 - in reply to #1498661)
Subject: RE: Propane and galvanized pipe
Seaford, Delaware
Absolutely not!
Alan
Gifford
Posted 12/21/2010 16:35 (#1499044 - in reply to #1498667)
East Kansas, DeSoto
In my past it has even attacked some brass valves, not all. Must have had some impurities in them. Gifford
Edited by Gifford 12/21/2010 16:36
twraska
Posted 12/21/2010 18:37 (#1499192 - in reply to #1498661)
Wallis, TX
Hmmmm,
We used galvanized for years when dad sold propane. I thought maybe rules had changed so I called LP supplier and they use galvanized in their plumbing. I'm in TX , maybe the rules are different where you are.
hillfarmer
Posted 12/21/2010 18:39 (#1499198 - in reply to #1499192)
does propane and butane effect galvanized pipe different
DrZhivago
Posted 12/21/2010 19:50 (#1499380 - in reply to #1498661)
What about aluminum and zinc die castings used in regulators and zinc plated hose stems crimped to propane hose?
AR Plowboy
Posted 12/21/2010 19:57 (#1499400 - in reply to #1498661)
East Central Arkansas
I was thinking it was natural gas it was a problem with. I am not saying to do it but I know where there is a 20' section of galvanized underground that was put in several years ago by a lp gas company and as far as I know there hasn't been any problems.
riceman4300
Posted 12/21/2010 21:00 (#1499568 - in reply to #1498661)
South Louisiana
My propane co. put galvanize pipe in at my grain bins 17 years ago. So far no problem. I dont know why but there are many setups in South La. that use galvanize pipe even in residential applications. Not saying it is good but it is done a lot down here.
twraska
Posted 12/21/2010 21:33 (#1499657 - in reply to #1499198)
Wallis, TX
Shouldn't be much difference between butane and propane in what they affect. I doubt you are getting butane anyway, most likely you are getting propane. I do know that some hoses labeled for natural gas would not work for LP. The LP would break down the rubber and cause seepage in the hose.
Mike SE IL
Posted 12/21/2010 22:36 (#1499865 - in reply to #1498661)
West Union, Illinois
YES ... sort of ... maybe.  Unless a recent edition changed it the National Fuel Gas Code does not prohibit galvanized piping in gas installations.  Yes, there is a concern about zinc flaking off, but no more of a concern than copper sulphite from reactions between impurities in the fuel and copper in the system.  This is why you need a properly installed sediment trap (aka drip leg) before each appliance.
And remember, this is NOT the way to install it:
(sediment trap WRONG.jpg)
Attachments sediment trap WRONG.jpg (44KB - 870 downloads)
