Chebanse, IL..... | You must have different info than I on the dd xmission. Reading the European JD's (ploughing vs plowing) bulletin it doesn't say it's the same as an IVT. As a matter of fact, they highlight the efficiency of the dd vs the IVT. I doubt anyone argues the efficiency of mechanical drive vs partial hydraulic (IVT) or any hydraulic drive. However, I really enjoy our IVTs.
New DirectDrive transmission for 6R Series
With the newly designed 24-speed DirectDrive transmission, John Deere has introduced a completely new technology to the agricultural machinery industry and a further option to the new 6R Series tractor range. This double clutch technology is already established in the prestige car industry, and is now available in a tractor for the first time.
It has been designed to serve the needs of larger arable farms and contractors. The DirectDrive transmission combines the handling comfort of an infinitely variable shift transmission (IVT) with the power efficiency of a mechanical transmission, and has been designed for specific tasks and load conditions which require continuous power flow, such as ploughing and towing, pto work and road transport.
Key customer benefits of this new transmission are enhanced power efficiency and improved fuel efficiency, resulting in savings of up to 10g/kWh compared to an IVT transmission. Additionally, just like in Formula 1 racing cars, electromagnetic actuators enable fast changes between speeds and ranges under varying temperature conditions, to make this transmission even more productive.
The operator can choose between a manual mode to take command of forward and reverse speed changes via the control lever, and an automatic mode. In this mode, the three range DirectDrive transmission enables fast changes between eight speeds under full load, and also provides fully automatic changes between the A, B and C ranges.
Depending on the actual load, the Efficiency Manager function optimises the tractor’s efficiency by automatically matching the appropriate speed and engine rpm. As a result, the new DirectDrive transmission offers a cost-efficient alternative to existing IVTs.
Compared to the mechanical/hydraulic power split of an IVT, the DirectDrive transmission exclusively builds on a fully mechanical power flow. This results in a power efficiency improvement of approximately four per cent, without compromising operator comfort and productivity.
The straightforward transmission design also provides a choice of driving strategies to match all tasks, including transport work at a maximum speed of 50kph with a significantly reduced engine rpm (in Eco mode).
