I put the JD steps on the 4040 and 4050. I remember there was an issue with the steps not fitting all 4050's there was a serial number break for some reason. Before my Dad passed away he took a header off the battery box step getting out with the old little steps. Luckily Co-op guy was here spraying and made sure he was okay, I was planting at another farm while he was working ground here. As Bobby mentioned the 3rd step is pretty close to the ground. In fact I used to remove mine when chisel plowing or plowing in cornstalks as a precaution from catching it on anything while going over uneven ground.
Edited by Von WC Ohio 6/29/2010 20:00
(P4210029 (Medium).jpg)
Attachments ----------------
P4210029 (Medium).jpg (130KB - 1371 downloads)
